1993 Ford F-150 Where to go from here?
POCKET95428
  • 1993 FORD F-150
  • V8
  • 4WD
  • 145,000 MILES
I have the Following codes not sure where to go from here as to repair.
code:
23- TP sensore out of self test range
28- loss IDM Right side
33- EGR not opening ( brand new EGR valve)
81- Air Management 2 failure
99- Electronic presure control circut fail (E40D)
I found these codes by using the jumper method and watching the service/ check engine light and the anolog meter methode, both ways where done KOEO and KOER
( Key one engine off)(key on engine run)
Tuesday, July 8th, 2008 AT 9:08 PM
BMRFIXIT
  • 19,053 POSTS
I would reset the system and drive it until codes returns
check 1st code come up
and fix as needed
if all returned check wiring and fuses
Wednesday, July 9th, 2008 AT 6:05 AM
POCKET95428
BMRFIXIT,
Thanks for the advice I have tried resetting the codes befor by the book, so I am letting the neg. ( - ) Terminale off for 24 hrs, I is also kinda hard to do a smoth drive after words due to where I live, My truck is rarely ever on pavment. Mostly dirt logging roads.
But thanks again
Wednesday, July 9th, 2008 AT 6:26 PM
BMRFIXIT
  • 19,053 POSTS
Check if you are missing any fuses
Wednesday, July 9th, 2008 AT 7:57 PM
