1993 Ford F150 Weird Problem?
204,000 MILES • V8 • 2WD • AUTOMATIC
FATT_FARM
I have a 1993 F-150 with 204K. I bought it without a radio and went to install an aftermarket one. I wired it all up turned it on and it all worked fine, i stepped out of the truck to throw away my trash my girlfriend slammed the door and told me the radio shut off. i checked all the fuses none are blown and wires are all connected fine. Radio still isn't working and whatever the problem is stopped my speedometer tripometer and odometer, my interior lights and my electronic mirror adjusters. i have no clue what went wrong since all the fuses are still good. any suggestions? thanks.
Jun 16, 2010 at 4:48 AM
  • 110,248 POSTS
Where did you get power from for the radio? Also, have you checked the fuses under the hood?
Jun 16, 2010 at 3:14 PM
FATT_FARM
yes, first i checked all the fuses that were on the diagram as radio and speedo and alll that, then i went and checked all the fuses in the fuse box by the steering wheel and then from the distrabution box under the hood. i got power from the radio from the black stereo wire in the dash.
Jun 17, 2010 at 4:02 AM
  • 110,248 POSTS
Have you had the body control module checked?
Jun 18, 2010 at 8:07 AM
FATT_FARM
No, i'm not sure where that even is
Jun 19, 2010 at 6:58 AM
  • 110,248 POSTS
I believe it is located behind the kick panel on your vehicle. It controls many of the electrical accessories.
Jun 19, 2010 at 4:13 PM
