1993 Ford F150 universal joint
192,000 MILES • V8 • 2WD • AUTOMATIC
LOKIO213
i would like know how to replase my universal joint
Jun 1, 2009 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
mark the driveshaft to the axle flange and the tranny flange.
then remove the yolks. once shaft is out remove the retaining clips and use a press to press out old oens and press in new ones.
be sure the tap the caps of the joints before installation so the joints dont fall apart and the needle bearings scatter away.
Jun 23, 2009 at 4:13 AM
