1993 Ford F150 Shift lever
157,000 MILES • V8 • 2WD • AUTOMATIC
RWANGARD
Shift lever on column feels loose and does not shift to proper piont, ie park, reverse or drive. If I feather lever around, transmission does work OK, need to know how to tighten linkage in steering column.
Jul 28, 2010 at 2:33 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check lower cloumn bracket low on column near bulkhead has to nuts see if they are loose. if good then maybe shifter pin is worn and/or return spring broken. Would need to disassemble column.
Let me know
Thanks for donate
Jul 28, 2010 at 7:37 AM
