1993 Ford F150 rear drum brakes dragging
1993 FORD F-150
180,000 MILES • V8 • 4WD • AUTOMATIC
BOWHUNTER6769
i had a front caliper come apart and drained the brake system of fluid. i have replaced both front brake rotars, calipers and pads. i have also replaced the rear drums, shoes, springs, and wheel cylinders. also have replaced the master cylinder. Now the problem is that the rear passenger side brake is dragging and getting hot. i have ruined one set of shoes because of this. i have bled the brakes but has not helped. when the brakes are appiled pretty hard the abs and brake lights come on. please help
thanks bill
Jul 2, 2008 at 6:44 AM
DOCFIXIT
  • 18,828 POSTS
Make sure the parking is loosened up before making adj to brakes. back off pk bk adj then adj brakes with a slight drag. Let me know what happens
Jul 2, 2008 at 6:55 AM
