1993 Ford F150 pilot bearing removal
1993 FORD F-150
20,000 MILES • V8 • 4WD • MANUAL
MARKDAMACK
I have a pilot bearing that just does not want to come out, I have used two different pullers and it won't budge! any insight would be greatly appreciated thanks MAH
Feb 19, 2010 at 7:04 AM
CJ MEDEVAC
  • 11,004 POSTS
If you are referring to crank pilot bushing......find steel rod that will tightly slip in and out of hole........next fill hole w/heavy grease......slip in rod.........give it a good smack w/heavy hammer........hydraulic effect should push him out. See my profile.........good luck......Love, Turddog
Feb 19, 2010 at 7:54 AM
