Engine Mechanical problem
1993 Ford F150 V8 Four Wheel Drive Automatic
Truck is pushing oil up into the air filter box. Pull rubber hose of air cleaner box and have very very slight smoke. Put truck in gear and give it a little gas and the smoke comming out that same hose is enough to use for mosquito control. PCV valve has been replaced and is working, has plenty of vacaum. What is causing this. Only started when we took the truck on first log trip pulling a pop up camper
Oct 16, 2008 at 12:49 AM
