1993 Ford F-150 Fuel
MICHELESQUIRES
  • 1993 FORD F-150
Computer problem
1993 Ford F150 6 cyl Two Wheel Drive Manual
I have a 93 ford f150 that is realy giving me a hard time fixing it. It all started Going down the road it stalled out with me and the check engine light came on and then it ran fine all the way home well when I went to crank it again about a week later it wouldnt crank and the fuel pump comes on but never shuts off.I have checked the relay and the preasure reg and changed the fuel pump and went and got a new computer and its still not changed. HELP ! I dont know what else to do next.
Tuesday, August 10th, 2010 AT 11:13 AM
  • 109,885 POSTS
Are you sure the regulator is good? Also, are you getting spark to the engine?
Tuesday, August 10th, 2010 AT 10:19 PM
MICHELESQUIRES
Yes im getting spark Every now and then when the pump desides to go off (witch has only happened 2 or 3 times)The truck will crank fine and run for a few min and then the pump will come back on and the truck dies(floods its self out). You can reach me derect at michelesquires@gmail. Com cell 706-973-9382
Tuesday, August 10th, 2010 AT 11:19 PM
  • 109,885 POSTS
I'm sorry, but I'm not allowed to contact you directly. What I need you to do is check fuel pump pressure and the regulator.
Here is a how to. It has directions and a video as to how to check both.
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
NOTE: You will need a gauge. Most parts stores will lend or rent them to you.
Let me know what you find.
Wednesday, August 11th, 2010 AT 12:22 AM
