1993 Ford F-150 Front Rotor replacement
SMOHRMAX
  • 1993 FORD F-150
  • 6 CYL
  • MANUAL
  • 100,000 MILES
What's it take to replace the front rotors of a 1993 Ford F150, 5 sp manual trans, 2wd, 100000 miles.
Looks like I need to remove the hub nut. What size would that be, 35mm, What is the ft lb torq requirement. I've replace other rotors but never had to remove the hub nut. Do I need to worry about bearings and repacking?
Thanks
Steve
Monday, December 22nd, 2008 AT 3:26 PM
DAVE H
  • 13,384 POSTS
Removal & Installation (2WD Models)
Raise vehicle and support with safety stands. Remove wheel and caliper assemblies. Remove dust cap, cotter pin, nut, washer and outer bearing. Carefully remove hub and rotor assembly. Remove inner bearing and seal.
To install, reverse removal procedure. Adjust front wheel bearings. While rotating rotor, tighten adjusting nut to 17-25 ft. Lbs. (23-34 N.M). Back off adjusting nut 120-180 degrees. Install bearing retainer and NEW cotter pin.
Tuesday, April 6th, 2021 AT 12:09 PM
