1993 Ford F150 fluid leaks
COREY90
Brakes problem
1993 Ford F150 V8 Two Wheel Drive Automatic
on passenger side behid front tire, there is a small hose that came off a metal piece and thats where the brake fluid is coming out. What is the easiest way to replace this hose. Is it something that can be bought at auto parts store? and how would it be replaced?
Mar 22, 2009 at 9:50 AM
EUGENE123
  • 273 POSTS
if you know where the leak is coming from then simply remove the rubber hose go to a parts store and buy a piece of hose the same length and width of the one on the vehicle also buy two clamps to clamp on the each end of hose then take new hose and replace where old one is if you have any more questions about this repair please let me know
Mar 22, 2009 at 4:42 PM
