1993 Ford F-150 clutch
FELECIAPRICE
  • 1993 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 23,600 MILES
This has happened twice. I go to push in the clutch and it stays to the floor. I can pull it back up and it works but when the truck is on it won't go into gear. If you turn the truck off put it in gear then start it. It will then go but you can't shift to another gear.
Thursday, December 10th, 2009 AT 1:26 PM
  • 109,874 POSTS
Is the clutch resivour full? If it is, chances are the slave cylender for the clutch is bad.
Thursday, December 10th, 2009 AT 1:41 PM
FELECIAPRICE
It wasn't completely full. Can you change the slave cylinder without take out the clutch?
Thursday, December 10th, 2009 AT 3:16 PM
FELECIAPRICE
Both times I have had these problems it has been below freezing. Do you think the clutch fluid is freezing up? If so is there a additive?
Friday, December 11th, 2009 AT 1:22 PM
