1993 Ford F-150
PHIL0905
  • 1993 FORD F-150
1993 Ford F150 6 cyl Four Wheel Drive Manual
on my f150 the rear fuel pump has gone out can I tack this tank out all togeth and use a stander fuel pump
Friday, August 20th, 2010 AT 2:04 PM
MERLIN2021
  • 17,250 POSTS
Your has two low pressure pumps, one in each tank and a high pressure pump on the frame, you can transfer it over to a single tank system, but it might cost as much or more to do it. You'll need to get a high pressure pump for your front tank and eliminate the high pressure pump on the frame.
Friday, August 20th, 2010 AT 2:08 PM
PHIL0905
Thank you for
Friday, August 20th, 2010 AT 2:18 PM
MERLIN2021
  • 17,250 POSTS
Always here, your welcome.
Friday, August 20th, 2010 AT 2:33 PM
