1993 Ford F-150 clutch bleeder
154,000 MILES • 6 CYL • 4WD • MANUAL
HAYES300
my clutch bleeder is leaking and it moves side to side. first i thought easy fix its my master cylinder but it still losses pressure and is leaking constantly. i have narrowed it down to the bleeder. it moves left and right and im guessing that's whats leaking but im not sure how to fix it. my bleeder valve is sealing fine its the part up in the bell housing i can look into the window on it and move it side by side. so what does this mean?
Sep 28, 2010 at 7:25 AM
WRENCHTECH
  • 20,760 POSTS
That would be the clutch slave cylinder you're referring to. It will have to be replaced but unfortunately the transmission would have to be removed to replace it.
Sep 28, 2010 at 7:39 AM
