1992 Ford F150 Starter wiring?
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCORPIO110103
  • 16 POSTS
Is the lug with the thick wire on it the ground or the power lead? I thought it was the ground but, when I took it in to have it tested, they put the power lead to that lug! I'm confused.
Aug 25, 2009 at 9:27 AM
  • 75,988 POSTS
That cable comes from the starter relay and goes back to the battery it powers the circuit to the starter
Aug 25, 2009 at 11:01 AM
SCORPIO110103
  • 16 POSTS
How come when I wired it this way, I got a massive pop from my negative battery terminal when I went to reconnect it?
Aug 25, 2009 at 11:05 AM
SCORPIO110103
  • 16 POSTS
I didnt explain well enough,...I was talking about the 2 terminals on the starter itself,..1 of them has thick bare wire going back into the starter case from the solenoid,..is this the power terminal OR the ground?
Aug 25, 2009 at 11:08 AM
  • 75,988 POSTS
The thick bare wire is the hot circuit attach to the battery terminal of the starter solenoid the little wire is to energize the solenoid from the ignition switch the starter itself is the ground circuit.
Aug 25, 2009 at 11:28 AM
SCORPIO110103
  • 16 POSTS
THANK YOU! =)
Aug 25, 2009 at 11:34 AM
SCORPIO110103
  • 16 POSTS
Wait,.but then where does the ground wire hook up to then?
Aug 26, 2009 at 4:53 AM
  • 75,988 POSTS
There's is no ground wire on the starter when you hit the key to start the little wire energizes the solenoid at which time the solenoid shorts out and full battery is being applied to the starter
Aug 26, 2009 at 6:54 AM
SCORPIO110103
  • 16 POSTS
Where should I put the ground wire to then?
Aug 26, 2009 at 7:01 AM
SCORPIO110103
  • 16 POSTS
When I took my old starter off,..I was left with a ground wire I do not remember where it goes,..if that helps,...the bolt heads broke off,...had to slowly remove them with a vise grips,..
Aug 26, 2009 at 7:05 AM
  • 75,988 POSTS
What ground wire do you have down there on the starter-what color is it
There's only 2 wires on the starter (1) red battery cable and (1) small red wire both of them goes to the solenoid.
Aug 26, 2009 at 7:11 AM
