1992 Ford F-150 Speed odometer
MR. TH
  • 1992 FORD F-150
  • V8
  • 93,230 MILES
Last month my curise controll stopped working.
2 days ago my Speedometer and my odometer stopped working. Could this be a bad speed sensor?
Also, do you think I should drive my truck on a 400 mile round trip? Will it stop running?
Please help,
TH
Friday, January 30th, 2009 AT 9:59 AM
DAVE H
  • 13,384 POSTS
Hello. Thanks for the donation. Much appreciated
Yes this could all be related to the speed sensor. If the vehicle is running OK in all other respects any trip should not cause any other failures. Obviuosly without looking at the vehicle we cannot guarentee this? Hope this helps
SPEEDOMETER (AEROSTAR, BRONCO, ECONOLINE, F-PICKUP)
Speedometer is inoperative; CHECK ENGINE light is illuminated and/or Speed Control is inoperative. The probable cause could be one or more of the following:
No power to Programmable Speedometer/Odometer Module
No vehicle speed support
Open ground
Inoperative Programmable Speedometer/Odometer Module
If there is no power to Programmable Speedometer/Odometer Module, check for voltage at Pins 1 and 3.
If there is no vehicle speed support check for approximately 3.5 volts AC between Pins 4 and 5 of Programmable Speedometer/Odometer Module with vehicle speed approximately 30 mph.
If there is an open ground, check for continuity to ground at Pin 2 of Programmable Speedometer/Odometer Module.
If Programmable Speedometer/Odometer Module inoperative. Check module
Speed Control Amplifier. Behind left center of dash
Friday, January 30th, 2009 AT 3:57 PM
