I'v replaced the map, temp ,tps,and oxgyen sensor and unhooked the battery to arease codes it is gas smokes at ilde driving hesta at half peddle. can the computer be the problem checking the sensor it says 4.0 to 5.0 volts with key on run I'm getting 8.0 to 11.0 mike
Jan 14, 2010 at 9:52 AM
