1992 Ford F150 Replacing Rotors
HARLEYDAD004
Brakes problem
1992 Ford F150 6 cyl Four Wheel Drive Manual
I am trying having issues trying to remove the front rotor. I also need to replace the front Caliper.
This truck has 4 wheel drive and it has been a while since I have done one.
Nov 22, 2009 at 7:07 AM
  • 110,248 POSTS
THere isn't any difference between this and others. Remove the caliper (two bolts hold it on) and remove it. THen remove the caliper. I recommend that you release pressure when depressing the caliper piston through the bleeder on the caliper and not through the master cylender.
Let me know if you have other questions or have a problem.
Nov 22, 2009 at 7:14 AM
