1992 Ford F150 quit running!
1992 FORD F-150
125,000 MILES • V8 • 2WD • AUTOMATIC
ILLINOISDUDE11
i was driving the truck down the road it stopped running just light i turned the key off , i,m leanning towards a ignition control module ,i took a test light and i,m getting power too the wire too the module and when i have a friend crank it the light flashes on the test light cab you help me
Feb 5, 2009 at 7:13 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 5, 2009 at 7:19 AM
ILLINOISDUDE11
yes we done all that had power too the coil ,we are getting fuel ,no spark , how do you determine if the control module bad !
Feb 5, 2009 at 7:34 AM
You need a special tester to determine it-Did you test the distributor pick-up coil and the coil's primary and secondary resistances?
Feb 5, 2009 at 1:31 PM
RANGERDANGER17
  • 224 POSTS
check the timing belt
Feb 8, 2009 at 6:34 AM
