1992 Ford F150 PARKING LIGHT REPLACEMENT
126,000 MILES • V8 • 4WD • MANUAL
ABZID
The passenger side parking light needs to be replaced.
How do you gain access to the bulb?
Jun 26, 2010 at 5:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
To replace the parking lamp you have to remove the headlamp. There should just be a few screws holding the headlamp assembly in. Remove those screws then pull the assembly out and disconnect the parking lamp socket from the headlamp body.
Replace the bulb. Installation is the reverse of removal.
Jun 30, 2010 at 2:42 AM
