1992 Ford F150 Parking brake pedal assembly removal
1992 FORD F-150
145,000 MILES • V8 • 4WD • MANUAL
RON DONALDSON
MEMBER
1 POST
How do I remove the parking brake pedal assembly, ie. disconnect the cable from the assembly?
Aug 27, 2010 at 11:48 AM
✓Experienced Mechanic
The tension needs removed from the cables. Then at the end of the cable, it will have a lead ball that you will slide forward and out of the catch.
Aug 27, 2010 at 5:37 PM
