1992 Ford F150 Leaking coolant
150,000 MILES • 6 CYL • 2WD • MANUAL
EMP357
After I turn off the ignition coolant is leaking like crazy. After looking, it seems to be coming from where the fan belt attaches to the main engine (not sure what this is called). Any advice?
Sep 15, 2010 at 12:16 PM
WRENCHTECH
  • 20,760 POSTS
That sounds like the water pump is leaking. You should pressure test the system to confirm that.
Sep 15, 2010 at 12:33 PM
