1992 Ford F150 HELP!!!
125,000 MILES • V8 • 4WD • AUTOMATIC
TODD40
I have a '92 F-150 4wheel drive. I love my truck but I get the worst gas mileage ever. I have to have some compression problems b/c I cannot get full power with my EFI V-8. It is always downshifting to get the power and it sucks the gas right out. I was thinking it may be an exhaust leak at the manifold, but not sure. I changed plugs and that didn't seem to help. Went camping the other day and in Arkansas there are a lot of hills. My buddy thought my truck was a 6 cylinder b/c he didn't suspect that a V-8 would struggle so much... Any suggestions? Anything would be greatly appreciated.
Jun 18, 2008 at 2:55 PM
BMRFIXIT
  • 19,053 POSTS
You need to make sure engine running at all cylinder as a 1st step
check wires cap and rotor
bad wire will cause it to run very rough under load
check and replace fuel filter
I would start with a full tune up as a 1st step
Jun 18, 2008 at 10:47 PM
