1992 Ford F150 gaskets
356,872 MILES • V8 • 4WD • MANUAL
SOLONOR
I recently had to adjust a rocker arm, when I removed the valve cover there wasnt a gasket, I put a gasket on the side I worked on, do I need to install a gasket on the valve cover I didnt work on?
Sep 20, 2010 at 6:04 PM
  • 31,937 POSTS
Hi there,
If there is no leak, i would be thinking that there is a gasket fitted, so if this is the case and there is no leak, leave it be.
mark (mhpautos)
Sep 20, 2010 at 11:56 PM
