1992 Ford F-150 fuel injestion
SDVAN
  • 1992 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 165,000 MILES
What causes a truck to flood the engine after it is shutoff it is flooded on restart
Wednesday, July 30th, 2008 AT 6:57 PM
BLACKOP555
  • 10,371 POSTS
Could be leaky injectors putting fuel into the cylinders with vehicle off, or it could be that the injectors are still being pulsed by the computer after its turned off filling up the cylinders.
Right after shutting off vehicle immedietely disconnect the fuel injector main harness, then when ready to start, hook back up and start.
Wednesday, July 30th, 2008 AT 9:32 PM
SDVAN
Thanks I thought it might be leaky injectors I will try unplugging to make sure it is not the computer.
Wednesday, July 30th, 2008 AT 11:13 PM
