F150 RUNS LIKE IT HAS WATER IN THE GAS
2003 FORD F-150
475,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SANTOS01
i COULD NOT GET BACK INTO MY ACCOUNT, SO i CREATED A NEW ONE..
HERE IS MY ORIGINAL QUESTION
2003 Ford F-150 • 4.6L V8 2WD Automatic • 475,000 miles
Get notified if there is a reply to this question (click to subscribe)
I drive about 1,500 miles a week. Heading into southern Texas, my truck acted like it was starved for gas, never died, but ran rough. Had fuel filter, and fuel pump changed. Drove 15,000 miles without a problem, did it again for about 200 miles, stopped for the night, it continued the next morning, drove 100 miles. Then it stopped. Drove about 12,000 more miles, then it did for 150 miles, then stopped
I have changed filters, tune up, oil change, different gas, the only thing in common I see is when the temperature outside gets over 100 degrees, has all ways happened in the south. Any ideas?
Reply
Expert
Jacobandnickolas
Jul 17, 2014.
ASKED IF THE ENGINE LIGHT HAD COME ON
Good Question, but NO
I had taken the truck to 2 different Ford dealers for help, but since they can not replicate the problem, they could not help me. I was told by one that there were no error reports, so maybe that helps
One suggested a spark jump, but that was just a guess
thank you
Jul 19, 2014 at 10:28 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge it may be low or something going on in fuel tank like blocking the pump.autoparts rent it
Jul 20, 2014 at 1:15 AM
SANTOS01
thank you
I will
running out of ideas, there is just no consistent method to follow when to expect the problem and long it will last
Jul 20, 2014 at 7:53 AM
