1992 Ford F150 front transmission seal
1992 FORD F-150
RHONDAMARK
Transmission problem
1992 Ford F150 6 cyl Two Wheel Drive Automatic
how do you change a front transmission seal?also how can you tell if your transmission is out or just the front seal is blown?
Apr 23, 2008 at 6:42 AM
MERLIN2021
  • 17,250 POSTS
Front seal is the pump seal so you'll need to pay carefull attention to the torque conveter shaft. If the pump leaks bad enough, car don't go!
Apr 23, 2008 at 6:46 AM
