1992 Ford F150 door locks
153,000 MILES • V8 • 4WD • AUTOMATIC
HERMS122
I have a 1992 Ford F150. The electric passenger door lock works but the drivers side electric lock does not work. The drivers door doesnt even make a clicking sound when the lock/unlock button is pushed. A second problem that I have is the driver's door sticks when trying to exit the truck. You usually have to forcefully push your shoulder into the door in order for it to open. It opens just fine from the outside though. I was wondering if these problems are connected or seperated problems. I have only had this truck for about 2 years and want to fix the door before I try to sell it. Do you have any inexpensive solutions? Thanks for you time.
Feb 9, 2009 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
Suspect you need lock actuator
and check also the door hinges
Feb 9, 2009 at 12:50 PM
