I was working on stuff and bumped the (overflow?)fitting and it now leaks. It looks to be a pressed fitting(?). Can I remove this fitting, tap out the hole and replace fitting with a brass thread x barb fitting? What is the bad thing that might happen? Is there a better way to emiminate the leak?[img:1e00889314]http://www.2carpros.com/forum/automotive_pictures/561437_Coolant_leak_1.jpg[/img:1e00889314][img:1e00889314]http://www.2carpros.com/forum/automotive_pictures/561437_Coolant_leak_2.jpg[/img:1e00889314]
Aug 19, 2010 at 2:56 AM
