1992 Ford F150 CAM
1992 FORD F-150
TONYJEAN
Engine Mechanical problem
1992 Ford F150 V8 Four Wheel Drive Automatic
I changed the firing order on the Cam and now it is out 180 degrees and it was installed correctly. What should I do now.
May 17, 2008 at 8:10 AM
BMRFIXIT
  • 19,053 POSTS
u need to set cylinder #1 @ TDC
locate the rotor that’s # 1 you can do the firing order from that point
May 17, 2008 at 10:31 AM
