1992 Ford F150 92 econoline van
SCOTT FORDVAN.
1992 Ford F150 225,00 miles
I have off white grease comming up the oil cap intake,I've been told that to repair this blown headgasket symptom. I need to remove the valve card and take it to get machined.Can you tell me what website to study, so I can learn about this job>Thanks
Mar 1, 2010 at 1:17 PM
CJ MEDEVAC
  • 11,000 POSTS
See my profile....Yes this is a symptom of bad HG or warped head causing bad HG (water mixing in oil, white goop)......Maybe fortunatly it is also a symptom of PCV (positive crankcase ventilation) system not operating correctly (removing bad vapors from crankcase).....See if/ replace PCV if not sucking vacumm properly......look for disconnected PCV vac. line.......dirty PCV Filter usually found in air cleaner (older stuff)
Take your rig to a shop and have cooling system pressure tested ($$$) to see if Head Gasket is leaking.........high / tech school Auto-mechanics Shop Class can maybe do this for you (call 1st).......they like to show off their stuff!(maybe NO $$$)
Love, Turddog
Mar 1, 2010 at 3:40 PM
