1992 Ford F-150 92 econoline van
SCOTT FORDVAN.
  • 1992 FORD F-150
1992 Ford F150 225, 00 miles
I have off white grease comming up the oil cap intake, I've been told that to repair this blown headgasket symptom. I need to remove the valve card and take it to get machined. Can you tell me what website to study, so I can learn about this job>Thanks
Monday, March 1st, 2010 AT 9:17 PM
CJ MEDEVAC
  • 11,005 POSTS
See my profile. Yes this is a symptom of bad HG or warped head causing bad HG (water mixing in oil, white goop). Maybe fortunatly it is also a symptom of PCV (positive crankcase ventilation) system not operating correctly (removing bad vapors from crankcase). See if/ replace PCV if not sucking vacumm properly. Look for disconnected PCV vac. Line. Dirty PCV Filter usually found in air cleaner (older stuff)
Take your rig to a shop and have cooling system pressure tested ($$$) to see if Head Gasket is leaking. High / tech school Auto-mechanics Shop Class can maybe do this for you (call 1st). They like to show off their stuff!(Maybe NO $$$)
Love, Turddog
Monday, March 1st, 2010 AT 11:40 PM
