1992 Ford F150
1992 FORD F-150
145,000 MILES • V8 • 4WD • AUTOMATIC
RODSHELL01
when i turn switch on the fuel pump starts and does not turn off. truck will not start and check engine light stays on. replaced fuel pump relay and fuel filter. when fuel pump turns off like it should it starts but will turn off when driving. what do i ldo to fix
Sep 8, 2010 at 11:31 AM
  • 110,240 POSTS
Have you checked the fuel pressure regulator? Have you had the computer scanned since the check engine light is on?
Sep 8, 2020 at 5:55 AM
RODSHELL01
changed fuel pressure regulator still doing same thing. when fuel pump cuts off runs great. what next...
  • 110,240 POSTS
You need to have the pressure tested while driving. Have you had the computer scanned yet since the check engine light is on?
