1992 Ford F150
SALVAZ
Engine Performance problem
1992 Ford F150 V8 Four Wheel Drive Automatic
The engine was receantly replaced and sounds good, but while driving it does seem to output the power it should. what could be the reason?
Jul 12, 2010 at 3:58 AM
MIKESHELDON
  • 15 POSTS
If you have replaced your engine then it should have been done by a professional team.If not then the car will give some major problems you should check your car for any fault which may have occured during the replacement of the engine.
Jul 13, 2010 at 7:54 PM
