1992 Ford F150
69,750 MILES • 6 CYL • 2WD • MANUAL
SANDRAGARIBAY
Need to find out how to remove water pump
Oct 16, 2008 at 3:57 AM
BLACKOP555
  • 10,386 POSTS
drain the radiator and the block of antifreeze first.
then mark and disconnect hoses on the water pump, after that remove the fan and clutch. from there you can unbolt and remove the water pump with no problem at all.
Nov 23, 2008 at 1:02 AM
