Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine Cooling
Water Pump
Replace/Remove
1992 Ford F150
1992 FORD F-150
69,750 MILES • 6 CYL • 2WD • MANUAL
SANDRAGARIBAY
MEMBER
1 POST
Need to find out how to remove water pump
Oct 16, 2008 at 3:57 AM
BLACKOP555
Experienced Mechanic
drain the radiator and the block of antifreeze first.
then mark and disconnect hoses on the water pump, after that remove the fan and clutch. from there you can unbolt and remove the water pump with no problem at all.
Nov 23, 2008 at 1:02 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
