Okay 1992 Ford F-150 2 wheel drive 302 Motor, Not sure what is going on when driving down the road the voltage gauge will be bouncing the voltage is reading anywhere between 11.6 to 14.4 volts while this goes on. When you turn the headlights on or hit the brake,roll the window up, the headlights dim dramatically for a moment but then return to normal.
Sep 16, 2007 at 4:04 PM
