Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine Cooling
Thermostat
1991 Ford F150 thermostat
1991 FORD F-150
165,000 MILES • V8 • 2WD • MANUAL
DIRTRACER222
MEMBER
1 POST
i was woundering wich way the thermostat goes in?
Dec 10, 2009 at 3:55 AM
Experienced Mechanic
Do you need directions for replacing it or just what direction to point it? If just the direction, the spring goes toward the engine. Also, check closely on the new t-stat. usually it will say which side faces the radiator.
Let me know if this helps.
Dec 10, 2009 at 5:42 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
