1991 Ford F150 thermostat
165,000 MILES • V8 • 2WD • MANUAL
DIRTRACER222
i was woundering wich way the thermostat goes in?
Dec 10, 2009 at 3:55 AM
  • 110,246 POSTS
Do you need directions for replacing it or just what direction to point it? If just the direction, the spring goes toward the engine. Also, check closely on the new t-stat. usually it will say which side faces the radiator.
Let me know if this helps.
Dec 10, 2009 at 5:42 AM
