1991 Ford F150 no hot air in cab
1991 FORD F-150
TC1912
Heater problem
1991 Ford F150 6 cyl Two Wheel Drive Automatic 130K miles
Hi, replaced heater hoses, blew out heater core (appears no obstruction). Water pump is new 6 months ago, as is thermostat and housing. 4.9L, E40D transmission. When engine reaches operating temp, the hose to the thermostat is hot, hose to the pump is cold! Again the core looks brand new and was easy to blow fluid by mouth through it. Still no luck with heat. The temp lever in cab has very little affect in bringing warmer air.
Hmm,
Thank you
Dec 18, 2008 at 6:11 AM
BLACKOP555
  • 10,386 POSTS
what hoses are not hot? can you get a picture and circle the hoses that are cold and hot? you may need a cooling system flush.
do the heater core hoses get hot?
why was the water pump replaced?
Dec 20, 2008 at 4:47 AM
TC1912
[quote:7cd87a7c8e="blackop555"]what hoses are not hot? can you get a picture and circle the hoses that are cold and hot? you may need a cooling system flush.
why was the water pump replaced?[/quote:7cd87a7c8e]
Water pump was replaced due to leaking, also thermostat and thermostat housing were replaced due to corrosion.
Both hoses get hot now. Both didn't get hot until I put some drive time on the vehicle. It appears now that when I use air conditioning then go to heat, the heat takes up to a minute or 2 to become functional. I believe this is an intermittent issue. I will keep testing and let you know the results.
Thank you
Dec 20, 2008 at 11:07 AM
BLACKOP555
  • 10,386 POSTS
alright get to me with the results. always keep your eye on the temperature of the heater core hoses, can tell us weather its blend door related or cooling system related.
Dec 20, 2008 at 11:42 PM
