1991 Ford F150 Ignition Switch
150,000 MILES • V8 • 2WD • AUTOMATIC
CMSHERM34
I have a 1991 F150, and the ignition switch rotates freely after the key is inserted, I replaced it and it still rotates freely without starting the vehicle, I cant figure out what the problem is. I bought a new switch with key and it still rotates freely, I know the problem is inside the steering column but what could it be and what is the part called?
Dec 21, 2007 at 5:04 AM
BLACKOP555
  • 10,386 POSTS
you did not need a new ignition switch, what you needed was a new ignition tumbler.
Dec 21, 2007 at 9:22 AM
