1991 Ford F150 ignition stays on
12,800 MILES • 6 CYL • 4WD • AUTOMATIC
JHNDHU
I have a 91 F150 4x4 auto trans 3 speed with overdrive, I believe it's a C6. I started it one day and when I went to shut it off, the key turned back to lock position, but motor did not quit. The dash lights stay on and the only way to shut off power is tto disconnect the battery. It has tilt wheel with cruise in the steering wheel cover. The only way I can restart it is to reconnect the battery, Put tilt in lowest position, hold key in start pos. and bang on top of column at tilt knuckle and it starts right up. At first I thought it was the key lock switch, so I pulled it and replaced it with a new one, and that made no difference. Can anyone tell me how to repair this, short of replacing the steering column?
Apr 6, 2010 at 2:09 AM
RACEFAN966
  • 5,029 POSTS
Ok first off your trans is an AOD if it has overdrive just for your info. Now with it not shutting off have you checked or changed the starter relay on the fender near the battery? See pic. Get back to me and we will go from there.
https://images.2carpros.com/forum/automotive_pictures/249564_51047_2.jpg
Apr 6, 2010 at 2:55 AM
JHNDHU
Hey guys, I already figured out the problem myself. It is the rod that connects the ignition key lock to the (accuator) on the steering column. Thanks anyway. IS THERE ANYWAY TO GET MY MONEY BACK, BECAUSEYOUR ANSWER DID NOT HELP, AND I FIGURED IT OUT MYSELF????????????
Apr 7, 2010 at 4:03 AM
RACEFAN966
  • 5,029 POSTS
Well that would have been our next look anyway I am just a mechanic that answers the questions by gathering info first I do not have anything to do with the moneys.
Apr 8, 2010 at 2:22 AM
