1991 Ford F150 hight oil pressure
1991 FORD F-150
100,000 MILES • 6 CYL • 2WD • MANUAL
JAHRAM
We had a broken head gasket. The head gasket was replaced and now the oil pressure is reading high. After driving the truck for about 2 to 3 miles it starts smoking trough the exhaust and at idle it starts shaking. After 15min of driving the check engine light also comes on. What could my problem be?
Apr 14, 2010 at 1:39 PM
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could be the oil pump and engine bearings
Also you need to scan the computer for code/s
Apr 14, 2010 at 7:26 PM
