1991 Ford F150 greasefittings
19,900 MILES • V8 • 4WD • AUTOMATIC
SHRN_LANHAM
i need to know where i can put grease in for the front end, i cannot seem to find the required hole to put in grease for a roaring noise. thanks
May 16, 2008 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
if your looking for a grease fitting on the transmission you wont find it, on the front end they are located on the ball joints, if they are not sealed. on the tie rods, drag link and other front end components.
roaring noises are usually a bad axle bearing. does it do it when in neutral while going down the highway or only drive?
May 16, 2008 at 9:14 AM
