1991 Ford F150 Cutting out when accelerating
DEEDSNMO
Engine Performance problem
1991 Ford F150 4 cyl Four Wheel Drive Automatic
I have replaced the fuel filters and plugs and wires. When you put in gear and try to accelerate the engine will cut out and not run. What could this be?
Jul 15, 2010 at 3:22 PM
  • 75,988 POSTS
Check the fuel pressure ifi ts within specs if okay do below
Test the knock sensor, throttle position sensor and manifold absolute pressure sensor
Jul 15, 2010 at 9:55 PM
DEEDSNMO
how do i check the knock sensor and the throttle position sensor and manifold absolute pressure sensors?
Jul 16, 2010 at 8:59 AM
