1991 Ford F150 cooling system
1991 FORD F-150
116,000 MILES • V8 • 2WD • AUTOMATIC
GEARJAMMER167
truck runs hot. cannot find any leaks. bottom and top hose on radiator is hot. bottom of radiator around drain cock is cold. cannot drain water from radiator thru drain cock unless truck is running then it gets hot around drain cock. i was also told it could be a blown head gasket can you help
Jan 9, 2008 at 5:46 PM
Try flushing the cooling system out and replace the thermostat and see what happens. Probably air in it and needs bleeding out.
Jan 9, 2008 at 5:52 PM
