1991 Ford F-150 A/C seems to run when I use defrost
SPB077
MEMBER
1991 FORD F-150
Air Conditioning problem
1991 Ford F150 6 cyl Four Wheel Drive Manual alot miles
my a/c clicks on and off (blows cold air) when I am just trying to use derost
Saturday, September 19th, 2009 AT 4:35 PM
PEAR69
MECHANIC
That is normal. When the defrost is activated, the a/c is also activated.
SPONSORED LINKS
Sunday, September 20th, 2009 AT 5:03 AM
SPB077
MEMBER
1 POST
Thanks for reply, I made a donation when I jioned. The a/c should run when above a certain outside temp I found out. But this one turns on all the time, even when it was only about 50 degrees the other morn. Do you know where it gets its temp from so I can replace that. Sensor?
Sunday, September 20th, 2009 AT 3:39 PM
PEAR69
MECHANIC
The ait sensor will be in the air intake tube. Sometimes it will be behind the grill on the right side, behind or in the intake tube.
