1991 Ford F150 V8 Four Wheel Drive Manual
the air conditioning works great as long as you are moving but when you stop compresser kicks on and off but as soon as you star moving it works like it should.I checked with gauges everything checked good. Could it be low pressure switch. When you stop it slowley stops cooling but you starty moving again all ok
SPONSORED LINKS
Tuesday, July 7th, 2009 AT 10:44 PM
