1990 Ford F150 Truck won't shut off
170,000 MILES • V8 • 2WD • AUTOMATIC
BENCHR
I have a 1990 F150 and for the past few days it seemed like once I turned the key it hesitated a second before starting, or I had to turn the key a little bit further than usual. Today I started it fine but then it wouldn't turn off. I turn the key back and can even remove it, but the truck stays running. I bought and installed a new lock cylinder but that didn't make a difference. Help please.
Dec 1, 2008 at 7:26 AM
  • 75,988 POSTS
Could be that the ignition switch power feed is touching the ignition circuit contact intermittently in the igniton switch or the wires itself
Dec 1, 2008 at 7:34 AM
BENCHR
Ok, but how do I check that or fix it?
Dec 1, 2008 at 8:51 AM
  • 75,988 POSTS
Sir-if you're not competent in electrical and the use of a DVOM your best bet is to have a professional check it -it can be complicated and also you might end up making things worst if a mistake happens-
Dec 1, 2008 at 9:34 AM
BENCHR
That's unfortunate. I'm trying to sell the truck and I really don't want to put any more money into it. Thanks
Dec 1, 2008 at 9:47 AM
