1990 Ford F150 troubleshoot starting
SKYROCKET
Engine Mechanical problem
1990 Ford F150 V8 Four Wheel Drive Automatic
how do i determine if a fuel injector is bad
May 31, 2010 at 7:22 AM
BLACKOP555
  • 10,386 POSTS
you can ohm them out and see if they have high resistance or a open. other thing you can do is perform a cylinder balance test or a fuel pressure drop test for each injector. one flowing lower then the rest or more then the rest indicates a problem
Jun 1, 2010 at 3:52 AM
