1990 Ford F150 netural saftey switch?
SCRAPPYDOO
Electrical problem
1990 Ford F150 V8 Four Wheel Drive Automatic
My truck will crank over if you jump the soleniod but not with the key. I have replaced the solenoid,starter,and ignition switch. Could it be the neutral saftey switch? if so where is it located.
Feb 23, 2010 at 10:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
neutral safety switch is located on left side of the transmission. try starting it with gear selector in neutral.
Feb 23, 2010 at 10:49 AM
